Hi all,
I have a Santon Premier Plus Imersion heater in a stanadard unvented system and have an issue...
My immersion heater comes on for a couple of hours in the early morning to provide us with hot waterfor the day. This has been working fine for years but recently I have found that the water is luke warm in the morning and almost cold by the evening whereas it used to be very hot in the morning and still quite warm in the evening.
When I use the boost then it is fine so I think the heat must be disspitating somehow. I have felt the pipes a number of times after a boost and the cold water feed is still cold and hot water outlet is luke warm. I have checked for a leak on the hot water taps/showerheads but have not found anything. Also, there is no discharge into the tundish from the RV and expansion valve.
Does anybody have any ideas/thoughts on what might be going on?
