- Joined
- 2 Aug 2019
- Messages
- 68
- Reaction score
- 2
- Country
Should I change out all the old low pressure taps and valves after going unvented?
I recently had an unvented cylinder installed. Our pressure is around 3bar and max flow rate via a water softener is c. 20l per minute. It's on the limit and one day we or the next owner's will have to bite the bullet and upgrade the capacity of the mains feed. But for the three of us, it should be OK.
Previously most of the hot cold/taps, toilets etc were fed from a large water tank installed in a bedroom cupboard, providing little gravity pressure for the top floor bathroom - this was offset by the use of gigantic imperial pipes (40+mm), so the flow rates were perfectly fine. And the flow to the middle floor bath was the fastest I'd ever seen (bath filled in a couple of minutes).
Now, post installation, the flow rate to the bath in the top floor bathroom is similar, but we now have a thermostatic shower that is excellent.
The old restored Mira 8 shower (c 1964) on the middle floor runs beautifully, and you can run the two showers at the same time without a large impact on flow rates. The middle floor bath, fed by these big pipes, when running on its own is similar to the top floor in flow rate. However, this outlet is "greedy", and if running at full pelt, starves the upstairs outlets if you try to use them.
After the change, two of the toilet float valves leaked and needed to be changed to high pressure variants. I've tested the impact of flushing the toilet on the Mira shower and there is little change in flow rate and no unacceptable change in temperature?
So, is it worth doing any of the following:
- Put bigger hoses on the water softener?
- Change out/put restrictions on taps designed for low pressure supply? Would this reduce the middle bath's "starvation" of other outlets?
I'm tempted to replace the Mira 8 with a thermostatic shower - but it is disruptive and I like the idea of having a well regarded old shower valve.
