UPDATE - Renovation of downstairs cloakroom toilet
16 Oct 2010
Berkshire
Absolute novice at DIY so this is probably a simple question.
Could you tell me if this sounds like a realistic plan?
1) plumber removes toilet, sink and radiator. He also seals water pipe so I can turn water back on
2) he goes and I paint for a few days
3) carpet right or whoever come and lay floor
4) plumber comes back and fits brand new toilet sink and radiator
Is that doable or have I got the wrong idea? Plumber is coming Monday to quote
Sounds like a plan to me. Don't forget to keep your plumber happy with copious amounts of strong tea. And biccies. ;)
I'm good with tea and coffee making for tradesmen so will do that easily. Hoping to get a quote for around £200-250 for the plumbers work (not including parts which I will buy) - think that's reasonable?
If I disconnected the sink taps, do I buy something to stop all the water coming out I turn it back on? If so, does it have a special name?
Same for radiator - thinking about trying this myself.
Not a special name just a plumber :)
If you're not sure about capping, I would leave to plumber. Not worth risk of a flood, compared to the few quid it will save.
I will take your advice!
What do you think is a rough price - about £250 to remove items, and cap them... Then come back a couple of weeks later to refit new stuff?
Unless using wall hung toilet and sink then flooring wants laying afterwards! Carpet fitter will cut around base of pan/basin pedestal (and any other obstructions), the plumber wont!
Indeed, get the carpet fitted after all other works are complete.
Really? All the sites say the toilet sits on top of the newly laid floor...
It's just a standard toilet - with a bit that sits on ground.
Sanitary ware down first - flooring after. Vinyl can be easily damaged during plumbing works.
That'll look sh**. The trick is for them not to damage the floor while fitting the sanitary ware. Then again on that budget, for 3 visits, you're probably right.
UPDATE
Plumber came out this evening. Said that he could remove sink and radiator no issue, and also block off the pipes so that I could spend a few weeks painting.
Bit more complicated with toilet. It's a really old one with a big cast iron pipe coming out the back which is cemented on and goes into a cupboard thing.
He said it would be tricky but doable. However, he would also have to build a kind of box thing on the wall, to house the toilet cistern as the cast iron pipe sits fairly far away from the wall.
Quoted:
£100 to remove radiator, sink and toilet + seal off the pipes
£180 to fit all the new stuff
Which I think it fairly reasonable.
