Regarding my previous post on this matter I contacted Drayton Help Line and they were very helpful indeed. They gave the following information...
Remove 'fuse' and make safe.
Remove the Manual Thermostat wiring in the 'airing-cupboard'...
Next on the ACL Programmer Model LP241 which is located next to the Glow Worm boiler downstairs...
Remove the Yellow wire on No 4 terminal and connect it to terminal No 3 on the SCR wallplate.
Then run a wire between terminal No 4 (which contained the yellow wire and is now empty) and terminal No 1. (Which contains 1 Blue wire)
Now what I am a little confused at is, when I removed the Manual Thermostat wiring I find that the Yellow wire is connected to a 'terminal-block' which also contains a White wire going to the 'Honeywell Motorised Valve' which was energised by the thermosts 'call for heat'
What I am now concerned at is, that the white wire is now left on the 'terminal-block' quite alone, with no other wires connected to it.
Could some kind person advise me about this 'white-wire' please. I do not want to upset the Valve in any way.
I have at this moment put the wiring back as it was until I get a reply to see if it is safe to go ahead with draytons advise. I am in no way doubting the advise given only trying to be 'cautious'
Regards
Below is the original post for you to read.
Bob UK
Advice please regarding the following...
Drayton Digistat SCR/RF1 Wireless Heating Control System -
This is intended to replace the Drayton manual thermostat, which is located on the outside of the ‘airing cupboard’ on the landing.
A Glow Worm Micron 80FF Fanned Flue Boiler provides our Hot Water system. This is located on the kitchen wall downstairs and is controlled by a Programmer...switching the system on/off twice daily. Life Style Model LP241,
I wish to remove the old Thermostat and replace it with the Wireless System, on the livingroom wall downstairs.
The wiring instruction for the Wireless System states: -
The SCR should be wired to the Combi boiler or central heating wiring using the correct type of cable or flex. The SCR should be wired in to replace hard-wired room thermostats.
Anyway looking at the front of the Glow Worm boiler 'electrics' there is a 'block-connector' there are 7 connectors and the wiring is as follows looking at it from left to right:-
Lp =LIVE – (Permanent)
Ls =LIVE – (Switched)
N = NEUTRAL
EARTH MAIN
EARTH PUMP –
Pl = PUMP LIVE –
Pn= PUMP NEUTRAL
In the airing-cupboard we find a 7 terminal block-connector.
The manual thermostat is connected as follows:-
(4) - Yellow wire (5) - Red wire (7) - Blue wire
Thermostat Info:- Drayton
Siebe Climate Controls Ltd
T45 RTS 1
also connected to the block-connector are:-
Honeywell Motorized Valve V4073A 1088
(1) Purple wire (2) Red wire (3) Brown wire
(4) White wire (6) Yellow/Green wire
Boiler thermostat
(1) Black wire (2) Blue wire (3) Brown wire
Regards
Bob UK
N = NEUTRAL
EARTH MAIN
EARTH PUMP –
Pl = PUMP LIVE –
Pn= PUMP NEUTRAL
T45 RTS 1
Boiler thermostat
