Before i started everything was working ok.I took out the 2 switches which both serve the same lights in the same room and replaced them with metal boxed ones.
I wired up the 2 switches but cannopt now get them to work the lights.
1 switch has a cable withjust the 3 wires , 1 to C which means circuit ,1 to L1 and 1 to L2 , all 3 go into the rear of the switch as before ,no probs.
The other dimmer switch has 2 cables each with 3 wires. 1 cables wires are connected as follows, 1 to ( back of switch into the Circuit connection ) one to earth and one to a plastic stop connecting to nowhere.
The other cables 3 wires are connected as follows, 1 to the same plastic stop and the other two into the rear of the switch L1 and L2.
The light bulbs work, and the circuit, when turned on and operating all other lights downstairs . What have i done wrong please.?
