The meter outside my flat indicates it is supplying electricity to my flat rated at 60 amps. However, when an electrician recently installed a new CU in my flat it was installed with just a 45amp 'base' fuse.
I'm concerned that if all my electric heating, cooker, hob, shower, dishwasher and lights run at once that this will exceed 45amps. Although the loads for these are split across 4 different circuits each protected with an MCB I can't help feeling far happier with a higher rated base fuse.
Questions :
a) Can I ask the electrician to come back to remove the CU cover and upgrade the 45A fuse to 50, 55 or 60 amps?
b) If my CU detects more than 45Amps is being drawn how will it behave? Will it trip all MCBs at once or will it pick one MCB at random and just trip this ?
c) Do I have a valid concern or should I stop worrying about my CU base fuse !
Questions :
