Hi All first post on this subject, just after a few pointers plese...
Like the title says I have upgrded from a old hot air gravity system that has never worked properly to a Condensing GLow worm boiler. Have plumbed in the hot water circuit (indirect) and this functions ok, no pump so it takes a long while to heat the DHW up but is loads better then the old system.
Now I am about to plumb the downstairs rads in and currently have mountd them in the right places. Next comes the actual plumbing that looks pretty striaght forward, well at least before it gets back to the boiler!
I have a pump and about to get a 3way valve and wondered if I need to reposition where the cold circuit feeds the system?
CUrrently its on the return of the copper tank, effectively dragging cold water behind it into the boiler as the hot water gets lifted out of the boiler by capilary action ( i think) . There is a expansion pipe on the copper tank inlet , so any excess hot water (blockage) has an escape path into the header tank. Looking at some diagrams the cold feed needs to be between the pump and the boiler on the flow out - does this need to be like this or do you think having the cold water feed on the return it will function OK???
ALso regarding the use of plastic / copper pipe , which would be better? I like the look of copper and will be using some of the excess 22mm to make the connections to the pump but wondered if I could use plastic on some of the feeds/returns to the rads to cut the cost a bit?
There seems to be loads of pushfit/comp connections to make the routing of the pipes easy enough although I may need to get the pipe benders/blow torch out to complete the pipe work near the boiler as I will need a awful lot of 90 deg/ t pieces to feed all the down stairs radioators which go off in three separate directions from a central point (concrete floor)
