I'm sure this question have been asked before...I've tried to search the forum, but haven't come up with anything really helpful.
Anyway, I've just bought a 2 bedroom semi. It's got a fully pumped open vented CH system with a loose lagged hotwater cylinder. I'm note sure when it was installed, however my guess is mid 70's. The boiler is a Concord WRS model, so that would make it about 25-30 years old...
Being a very old boiler I want to upgrade it to a modern (preferably a condensing) boiler. I think for my needs a combi would be quite suitable, don't take baths that often, and the mains water pressure is good.
As I understand the combi boilers tend to run on sealed CH systems, with higher water pressure. The pipe work is 15 mm connections to the individual radiators, and the 'back bone' is 22 mm (might even be 1"...).
Questions:
- I presume a conversion should not involve too much work? Mainly disconnecting loft tanks, etc.?
- Will the pipes be up to the higher water pressure?
- Is it possible to check this in a non destructive way?
I'm considering one of Worcester, Vaillant, or Baxi for the boiler. Favouring the Baxi 130HE at the moment because of its slim design (boiler is in the kitchen)!
Many thanks in advance for any help!
Questions:
