Hi there,
I have an in-line (I think axial) extractor fan in the bathroom. 100mm diameter located above the ceiling ducted to the external wall about 2-3metres.
The fan is almost useless as the room is always very steamed up after a shower. The fan barely holds a tissue when completely covering the vent!
I want to upgrade but think that it will be very difficult to install through a 100mm hole - not sure if a replacement will fit through?? For this reason, I was thinking of installing a surface mounted fan?
Can you advise please:
1) is it possible to work through a 100mm hole to replace the in line fan and if yes, what would you recommend?
2) What surface mount fan would you recommend and do I need to remove the inline fan ( I guess so!).
All thoughts appreciated!!
BTW...room is c. 12 cubic metres.
Thanks.
Thanks.
