Upgrading central heating / hot water - what's worth doing?
28 Mar 2006
London
We've just moved into a new house (4 bed, 1 bath, 1 shower) and were considering replacing / upgrading the heating & hot water before we start decorating.
We currently have a Potterton Profile boiler approx 10 years old, and a well insulated tank which is in good condition and has an electric immersion heater in it for emergencies. All of the radiators are about 30 years old and are mostly the old single width type without any sort of fins on them - none of them seem to show any problem signs at the moment.
We've had three plumbers around to give their verdicts, and had three different responses - could you help us understand which is likely to be the best option for us?
A) Replace the boiler with a condensing one, upgrade the tank, replace all of the radiators.
B) Keep the boiler (it hasn't died yet), no need to replace the tank (because it is in a good condition), replace only the radiators which are too big / small for the room, but fit all of them with thermostatic valves.
C) Install a Megaflow system, remove the tank, replace all of the radiators and install thermostatic valves on them all.
Efficiency is important, but not if cost is high and the gains are small. Eventually, we would want to add solar heating into the system - I don't know if that makes a difference...
What would you recommend?
From your description I would tend to go with A. You do not have to replace the rads or cylinder but as the rads are 30 years old, nows a good time to upgrade. They could spring a leak when the system is powerflushed after a new boiler install.
The boiler probably has at least another 5-6 years in it.
Modern cylinders are a lot better insulated. If you are seriously thinking of installing solar in the not to distant future then make sure you install a twin coil cylinder ready for this later.
consider the cost of (B) and ask yourself how long it will take to save the extra expense of A or C in gas usage efficiency.
Consider also giving it a good clean and adding a Magnaclean.
