- Joined
- 7 Dec 2007
- Messages
- 1
- Reaction score
- 0
- Country
Have been an avid reader of the forum for a while now, but this is my first post, so hello to all.
I am looking to update the heating and HW system in the new (to us, old to the world) house we have just moved into. At the moment we have a gravity system that provides next to no pressure to the 1st floor bathroom shower - which is less than 1m below the tank.
I've been advised by a few people to look into an unvented system as we would like to put a bedroom and en-suite into the loft space. I've read as much as I can find on these systems and realise that the incoming mains flow and pressure are vitally important. Therefore, to stop you all asking the same question - which I know you find annoying - the pressure and flow at present are:
Static pressure at washing machine inlet (just past kitchen tap) - 2.5 bar at 10pm and 2 bar at 7.30am
Flow from kitchen tap - approx 14l/min
Flow from outside tap - about the same, 14L/min
Dynamic pressure at washing machine when kitchen tap on full - 1 bar
As far as I can tell the incoming main is 22mm, I presume copper (?) but can't really tell - the house was built in 1953 if that helps. Pipework to kitchen tap (and washing machine) is 15mm copper.
I have had a couple of plumbers round, one of whom said we would be fine (without testing anything other than turning the kitchen tap on) and the other who measured the flow but not the pressure. Both are quoting for an unvented setup - although I was unimpressed with both of them so will be seeking more opinions.
I think that whilst the pressure is ok (not great but ok) the flow seems to be quite low. So my question is (finally) should I look into upgrading my incoming mains supply by fitting a new/larger pipe?
My real concern with this would be spending the x number of pounds it would cost without seeing any improvement. So I guess the real crux of the matter is - how do I know if upgrading the incoming main will give me enough flow and pressure to obtain good performance from an unvented system??
Sorry it's so long - I've got a load of info spinning round in my head and it's all splashed out at once.
