As you will have seen, Andy has now confirmed that such was his meaning/intent. No-one has suggested that this part of the discussion was really anything to do with whether or not an RCD must be fitted. It arose because sparkwright suggested that, personally, he would probably elect to install an RCD, even though an option would be to 'leave things as they are', with no RCD.I suppose but that is nothing to do with whether an RCD must be fitted or not.I'm not so sure about that. If Andy didn't consider the leaky element to be a hazard, then he would presumably regard it as an argument against RCD protection, since he would then regard what he described as a 'nuisance trip'
You tell me - I didn't postulate such a happening! I can, however, well see that moisture getting onto/into a (usually fairly exposed) S/H element could well result (at least until it heated up!) in enough of an L-E leak to trip and RCD, yet far far too little to cause an OPD to operate.Firstly, has it ever happened?i.e. do you see a L-E leak in an element (not large enough to rapidly operate the OPD), in the absence of an RCD, to be a potential hazard or not?
OK - fair enough - you seemed to be making a more general statement about requirements for RCDs. Mind you, as sparkwright has pointed out, before deciding that a S/H circuit did not require RCD protection (under current regs), even if there were no concealed cables, one would have to make sure than none of the heaters were in a bathroom and that no-one has slipped a socket into the S/H circuit.I was only referring to the storage heater.Is that not a narrow view of the (probable) intent, based on considering of only certain regulations? ... Why has there for a long time been a requirement for RCD protection of sockets likely to be used for outside equipment?
Kind Regards, John
