25amp?,,,,,so its 2.5mm supplying a shower of 9.5kw.............wouldent use that anymore untill that upgraded, or you might end up with a new toster....jeffO said:Many Thanks to Scoby.
Regarding cable size, I'm failry certain that it is 25 amp. The showering unit is rated as 9.5 [/list]
Scoby_Beasley said:Bleedin' Hell, have I just killed someone as their cable was under-rated? I'm gonna have to keep off this web site 'cos I assume people know what size cable they should use for different situations
ban-all-sheds said:[
So I fear he may not be aware of what size cable to use - he didn't ask what he should use, or how to replace it, so either he wasn't planning to do anything about the cable, or he does know, and does plan to replace it. But wouldn't someone who knew how to replace the cable from the CU to the shower also know how to replace an MCB
breezer said:ban-all-sheds said:[
as you said "never assume ANYTHING"
