I'm not totally convinced this belongs here, but then neither does it seem to totally fit on the other forums (mods: please move if appropriate).
I'm looking for recommendations for a cheap UPS (up to £100) to cover me for power outages of at least 30 minutes - this is a personal rather than a business thing, so I'm just looking for the best I can get for the budget rather than something cast-iron with support. The items to be powered amount to the following:
1 x router
1 x cable modem
2 x Sheevaplugs (small, very low power consumption, linux machines)
1 x external hard-drive
1 x external hard-drive caddy with 4 drives
1 x Gigabit switch
...and the reason I need a continuous power supply is mainly because Sheevaplugs aren't that robust when cold-booted in terms of mounting their hard-drives; the above serves a web-site (amongst other things) and some user intervention is currently required when there's a power outage, which isn't that useful if I'm not about.
In total, my cheapo power meter tells me that all of the above idles (disks spun-down etc.) at around 40-45W and peaks at 65-70W.
Now...having had a Google around, I see that APC UPS units come up quite a bit in the cheaper end of the market, specifically these:
http://www.apc.com/products/family/index.cfm?id=21
...and the 700VA version, from the specs, looks like it would cover my needs - ~£90. However, not all of its 8 outlets are battery backed up (I have 7 items in total) and I've no idea how well APC units are regarded (can't find many meaningful reviews). So...
Anyone any experience of lower-end UPS and have any recommendations?
Assuming I'm within the specs of the UPS, but the UPS doesn't have enough outlets for all of my items, am I OK to plug more than one item into an outlet?
Does using a UPS in itself increase power consumption greatly - I'm guessing they just charge, then trickle charge until needed?
1 x router
1 x cable modem
1 x Gigabit switch
