I recently drained my central heating down to replace the pump.
There were a couple of radiators that I don't think drained down fully because they were below the level of the drain cock but it was enough for me to work on the pump.
System is now back on - I've bled all the radiators (except one as some silly sod has built a cupboard right next to it and I can't fit the key in to bleed it) until water comes out, but after just 20 mins of the pump being one upstairs radiator is full of air.
I've bled all the radiators again starting downstairs but none of them have air in bar the upstairs one.
I've checked the F&E tank in the loft and it has water it in. The pump is on the lowest setting and definitely with the arrow in the same direction as the old one.
The system is (I think) gravity fed HW and pumped CH.
Any suggestions as to what is happening?
