Our CH system is about 25 years old, and we've lived in the house 13 years. We've always had unreliable heat upstairs, but recently it has got worse, all the upstairs rads are now cold, with the exception of the one directly above where the boiler is, which is luke warm. The water in the expansion tank in the loft, meanwhile, is boiling hot, as are the downstairs radiators, and the hot water cylinder.
We had a new pump fitted a few weeks ago, and a new downstairs radiator, and it seems to be since then that the system has deteriorated.
I've called British Gas (who fitted the pump and the radiator, under their Service Plan agreement for free), and they came and had a look and said I needed a power flush at a cost of £515! If this cures the problem, then all well and good (though it sounds expensive), bit I'm not convinced it will, and don't want to fork out for nothing.
I did notice that on the radiator above the boiler, the inlet pipe was hot, but the outlet pipe was lukewarm. Thinking this implied there was a blockage in the radiator, I took it off and jetted it out. The water was black, but no heavy sludge and no blockage, and since putting it back there's no difference. The pipes on all the other radiators are cold.
All help appreciated, particularly if it saves me £515!
