Hi all,
I have noticed these last few days (having only just switched off my heating), that when the hot water comes on, the radiators upstairs are also coming on (downstairs remain cold). I suspect this is an issue with the 3-way valve or some related item but just wanted to see if there was any advice on checks or fixes I could apply myself before calling in an engineer. I know the simplest solution in the short term would be to shut the valves on the upstairs rads, but unfortunately they're almost all knackered and leak when closed or are seized fully open.
I've checked the actuator head (which is a BGMVSP-23) and when switching between hot water only and heating+water, the little switch on the side is moving between the W and M positions, and it is set at the correct position when the water only is on. However all 3 pipes from the valve are hot when only running the hot water. We recently had some rads and valves replaced downstairs and had a few weeks of issues with airlocks and balancing the system afterwards. Not sure if this could be related or not (though I thought we had resolved all those now).
If I understand correctly then the actuator can be removed and the valve tested independently (though I've no idea how to do this). I'm happy doing some basic checks but if it's likely a drain down and replacement of anything plumbing related is required I will just get a professional in. Any advice welcome.
