Hello all, my first post and I hope someone can point me in the right direction!
My RCD has tripped at random a few times over the last couple of days. After turning off the upstairs ring main breaker the RCD stays on no problem (turning this breaker on again trips the RCD, so I'm pretty sure it's the upstairs ring main). All our lights are ok and the downstairs ring main is fine.
Our combi-boiler is connected to a spur off the upstairs ring main and initially I wondered if it was causing the fault, however I've wired that to the downstairs via a 13amp plug and extension lead. It's worked fine so far and no trips, so I've ruled that out.
What's really confusing me is that now, even with nothing plugged in upstairs whatsoever, if I switch the breaker on, it trips the RCD again (although after some delay). My brother-in-law (who's an electrician) suggested that water or condensation might be getting in somewhere, but there's no visible evidence. However, it was raining both times when it happened randomly and when I tried switching the breaker back on this Sunday, a nice sunny day, it was fine all day.
I know that I'm probably going to have to get an electrician in, but before I do, I'd be grateful for any ideas of things I could check!
Thanks,
Nick
Thanks,
Nick
