Hello,
Please can you advise the appropriate lubrication for UPVC windows / door locks and their mechanisms?
Internet advice is contradictory and I want to do it right. Hopefully this site will be able to give me a professional view:
Locks:
Ultion cylinder locks (I have 2 of these): Ultion advise using Lution XM https://www.ebay.co.uk/itm/Lution-XM-Lock-Lubricant-/183993444800 I am happy to use this but have read Kasp 30050 is the same product at half the price https://www.ebay.co.uk/itm/Ck-K3005...189482&hash=item1ab0ee006b:g:yF4AAOSwUqhgBdT4
Should I stick with the Ultion recommendation?
Yale Platinum 3* cyinder locks (I have 2 of these): Yale web info suggests using a PTFE lubricant. I called today and asked if I could use the graphite like the Ultion lock. They advised using GT85 or WD40. The reference to WD40 means I lost confidence in them.
Would the Ultion graphite lubricant be ok for the Yale locks? Alternatively would 3 in one with PTFE be ok, or should I go to the GT85?
I have also read I can use a silicon spray for the locks. Is that ok or should I use one of the above?
Windows and Doors:
Window espagnolette; door shootbolts, cams lock latches, mechanism etc: Is the 3 in one oil with PTFE ok for these parts, or would a silicon spray / something else be better?
Window and Door hinges: Is the silicon spray ok for these? 1 hinge started to make a noise and it was previously cured by using this.
Thank you for your advice,
Pete
Locks:
Windows and Doors:
Pete
