upvc door contact, how?
5 Mar 2008
Antrim
how do you pro's put a door contact on a upvc door when the door sits out 10+ mm from the frame :rolleyes:
its also slightly angled giving a gap both ways.
screw it on same as normal.
being upv it does not affect the magnetic filed.
but to be 100% sure fit it with blu-tac, connections outwards, and use a dmm to make sure it will work
thanks I wasn't sure if I could screw it on. ;) would a standard contact cope with a 15mm gap between the contacts as the door edge is angled.( nothing I can do to close that gap.)
