Moisture is getting across the void to the inner leaf, and the emulsioned skim is moulding slightly adjacent the door frame so I need some sort of vertical make-up trim externally to cover the door frame/add-on join?
Is it better to recess the external render up the side of the door frame a little, and lose the outer edge of the new trim in there, and then a bead of sealant all round?
Or just fix the new external trim with a film of sealant behind it, and then a bead of all round?
What sealant?
Tnx
Dain
What sealant?
Tnx
Dain
