Hi All
I am currently building an extension myself and think i may have done something wrong.
I am putting in a rear door (uPvc) which is the door and the cill.
I have installed it at 110mm from the concrete floor height.
I have to put down 70mm Celotex on the concrete base, plus 22mm for the floor, and then laminate/underlay etc which would be 9mm for the laminate and 5mm for the underlay would give me 96mm.
The question here is, when everything is installed, should the cill be see or should the cill be sited underneath the visible flooring? Currently the cill will be visible around 14mm
My uPVC front door, i cannot see the cill from the inside/.
No problem lowering it
Lee
Lee
