upvc door hinge
6 Oct 2016
hi we have a uvpc front door on the porch the door has dropped , and the hinges on the door frame have seemed to come loose, and I cant see any way to re tighten them are the hinges fitted when the door frames are made , the hinges on the door seem ok
any help please
thanks
post a pic of your hinge ...
some have a pin through , which will need to be removed to access the screws to tighten the hinge to frame screws. All hinges are screwed to door sashes as the frames are put together , different window/door manufacturers use different typres of hinges ... some photos will help identify how to help you
hi,
if you can't tight the screws you can lift the door putting washer shims on the hinges
