- Joined
- 25 Oct 2005
- Messages
- 5
- Reaction score
- 0
- Country
I have a problem with a UPVC door that will not open. The multipoint lock mechanism is a Fuhr, and from memory it has 4 rollers, 2 bolts and a centre bolt/sprung latch. The mechanism was making a terrible crunching noise and now the door will not open. Key turns in the lock ok, and the rollers and bolts appear to release as you can pull the top and bottom of the door slightly when unlocked. The centre bolt/latch does not appear to be fully retracting and therefore the door will not open. A locksmith has come out for a look and he reckons some internals in the multipoint mechanism have gone (stripped gears?). I can probably get a replacement multipoint mechanism, but I can't get the door opened to fit it! The door has 6 hinges and what appears to be a screwdriver slot on the top of the hinge pins. Is it possible to remove the door from the hinge side, or could I strip the panels off the door to get in to the mechanism to try to push the latch back?
I don't know how old the door is, but was here when we moved in 7 years ago. The lock cylinder was replaced 5 years ago.
Roobarb.
Roobarb.
