- Joined
- 2 Jun 2015
- Messages
- 4
- Reaction score
- 0
- Country
Apologies in advance as i think this question has been asked many times before and answered in a number of different ways, some of which will presumably be the answer i am looking for but I’m afraid i didn’t quite understand!
I would like to change the way the front door locking mechanism works. Currently the internal and external handle work in exactly the same way - Lift handle to engage locks, turn key to secure lock. The problem with that is we don’t like that when the door closes the handle must be lifted and a key used to lock the door.
I have a multipoint locking composite front door. It has eurocylinder locks (as standard i presume) and a single spindle. When i recently changed the locks i noticed there was a second spindle hole, which from research i believe is called an offset spindle? The handles seem to have switchable cassettes (They are Yale high security ones and ideally i would like to keep them if possible?)
The ideal situation would be that when the door closes, it can still be opened from inside and outside (to prevent accidental lockouts). Once on the inside though, if you lift the handle and engage the multi point locks, the door would lock and from the outside you would not be able to open the door without a key. Obviously overnight we would additionally lock the deadbolt from the inside to provide extra security.
Is this doable? If so, could someone be kind enough to describe what I’m looking for? Do i just need to buy a second shorter spindle and use the lower spindle hole in addition to the top one? Or do i need to buy a new set of handles?
Cheers
Andy
Cheers
Andy
