These type of pvc sills are supplied loose for nothing into the sides of the door slap foots,some then are tapped on with a hammer, some simply silicon'ed and screwed to the door frame bottom runner. You could quite simply fit a timber/metal/plastic one on in similar fashion. Just make sure any drain holes in the bottom runner are kept clear.
