UPVC door will not close on catch
2 May 2013
Hi any advice please?
my back UPVC door has developed an annoying problem.
When you shut the door it not longer catches shut without slightly lifting the locking handle.
The door has 3 flag type hinges with what looks like an allen type adjustment from the underside of the hinge. I have tried adjusting these allen bolts without any success.
Any ideas on how I can easily sort out this annoying problem will be gratefully accepted.
Is the actual catch on the door coming out of the door lock far enough...give it a gentle pull, if it pulls out further something has broken in the lock and you won't be able to door much about it except get a new door lock, however as gregers says may just be the latch plate has moved
