Hello all,
we have a backdoor on our house that we think was fitted about 5 years ago or so, we bought the ouse 4 years ago.
It has a standard (?) locking mechanism as far as i can tell, where you lift the handle, and it engages two claws and other bits (!) to lock it into the frame.
It's been a little characterful since we move in, but all you had to do was pull the door in as you closed it, and that would enable you to push the handle all the way up, engage the claws and then lock it.
I had always assumed, that this meant the door was not quite aligning properly in the frame, and that was why we had to pull it in before the handle would go up.
Yesterday morning my gf could not manage to get it to lock, so I had a look and determined with the door open that it would not do it freely whetehr the door was shut or open, ie the frame was not influencing the outcome at all.
I pushed in the lock, and then tried the lever several times and finally managed to get it to all the way up, and for the claws to come out.
LUCKILY I also managed this when the door was shut, as due to the design there is no way to lock it unless the claws are engaged, the key will simply not turn
So my question is, is this something I might conceivably be able to tackle by myself, or should I get a professional in?
Presumably it must be the mechanism in the door, so simple tasks such as changing the lock is not going to make a jot of difference.
Worst case, does it sound like I might need a whole new door.....?
I nervously await your replies.........
Many thanks
Dan
Many thanks
Dan
