UPVC Door
16 Oct 2007
Could you tell me if it is possible to fit a letterbox and chain to an existing uPVC door, or do I have to replace it? Thank you.
wouldn't recommend fitting chain,as for letterbox,it depends on the door,and where you want to put the box.if it's a full height panel you can put it anywhere the raised mouldings will allow.you can't put it in the frame or the sash(outside edge of door).
