The floor is not level and so the bottom of the door is rubbing against the carpet floor (soon to be tiled) so I think I need to trim the bottom off it. Any thoughts?
since the thickness of the upvc will only be about 4mm if your lucky I wouldn't try it.
However, look at the hinges. See if there is a little plastic cap on them either on the side or top. You should be able to lift the door up about 5mm via the hinges. They usually have a screw adjustment.
Woody
