Am going to fit new 18mm uPVC fascia and have bought 65mm long pol nails 3mm diameter. Do I need to put a pilot hole on uPVC fascia and rafter for these nails or can they be driven straight in.
Small gentle taps till it goes through the facia, hit the nails square on as the polytops tend to come off and its a bugger trying to get the nails out.
Wouldnt do any harm if it makes you more comfortable.
Look out for freezing weather when doing the installation as the upvc is more susceptible to cracking.
