Upvc Frame add-ons
15 May 2018
Leamington
I've been looking around and having no luck finding the right profile add-ons/knock-ons/frame-extenders for fitting a composite upvc framed front door. They're either right profile and too short or the right length but different profile etc
Looking for 50mm with a height of 2100mm and based in Leamington/Midlands
Long time user of the forum first time poster!
The size required for the porch opening required the maximum size composite door plus 50mm. I took advice from a neighbour who had it done recently and its exactly what the door fitter did on their property as well. The doors standard aside from the fact it uses a different profile knock on to the local pvc supplier
If you don't know the make of the frame for the correct addon use treated 3x2 timber and trim over it with some 45mm or 65mm trim
