Evening
I've recently bought my first house and I want to replace the front door handle from a gold bashed up handle to nice new silver handle.
I have seen the handle i'd like to buy but what is really causing me some headache is the barrel lock, I just can't figure out what size I'd need.
The door is a standard UPVC door, around 68mm to 70mm in thickness.
The new handle has a backplate which is 15mm thick for the exterior and 10mm thick for the interior.
The website I want to order from has a measuring guide for the barrel which I have followed but I don't know if I have done it correctly.
I am ok to put links to the website I'll be ordering the handle and lock from to help? I'll add these later if ok and not against forum rules.
From the guide, I measured from the screw holding the barrel in its place, this is around 39 to 40mm. With the handle back plate that becomes around 55mm.
The handle I have seen has a cover which kind of sits over the barrel . . .
so do I buy a barrel with a front measurement of 55mm or do I need to allow a extra 5mm on the barrel as the guide mentions?
The back section of the door when measured from the screw is around 30mm, with the internal handle back plate = 40mm . . . so do I then add another 5mm on this also.
Sorry for the basic questions, i really am a DIY noob so wanted confirmation before making an order.
Thanks for any help
Thanks for any help
