I have a 3m x 4m conservatory, upvc windows on both sides with double doors in the ctr of the 4m frontage with windows either side of the doors. Recently I have noticed the top of the door and window frames sagging making it difficult to close and lock the doors. I removed the utility board above the windows to the ceiling for investigation into the problem and found chocks of wood between the frames and the wooden roof joists which are taking the weight of the flat roof almost directly onto the frames.
Should the FENSA registered window company who fitted the windows and doors also have fitted a steel lintel and vertical supports to strengthen the frames over the 4m length. And do I have any rights even though the warranty has run out?
Thanks in anticipation.
Worried.
Worried.
