UPVC window draughty - already as tight as can go
17 Dec 2016
I have some draughty UPVC windows that are already as tight as they can go on the cam.
They are south facing so I think over time the seal has hardened slightly and therefore isnt quite as good as it used to be so they are draughty in the corners. As such i wondered if I could add an additional seal somehow as looking at the window the current seal looks like it was fitted when the frames we made.
Grateful for any advice.
on some windows you can buy new seals and fit them yourself
Which corners are you getting the draught ? Hinge side or lock side? By the sounds of it you have seals that you are not able to replace ( with a picture we could confirm that ).
