Hi there, have some problems with a window and looking for some advice.
I'll get straight stuck in, the window has a leak, but this gap in the frame is allowing wind to push water straight inside the building, causing rot on the sill which has now been removed.
Here is the window in question;
and a close up;
As you can see the tiny gap is in the lower part of the frame and not where the window actually closes. It may not even visibly show, but this gap causes the entire room to be unusable due to the freezing draught.
I went and took a look outside with the ladder, then discovered this;
As you can see the light shines straight from the outside in, I'm assuming there should be some gap on the outside to allow any water drainage? but should it come straight through like this?
finally, don't know if it helps but when the weather is bad, water collects in window frame, as shown below;
I'm no expert with windows, and due to my schedule I'm unable to get someone to look at it for a good few weeks, so I'm in dire need of advice on how to fix this problem and hopefully it's something I can get done asap in my available time.
You guys think I can repair this? or is the frame knackered and I need a new window entirely?
Thanks for any help here, and I'll reply to any questions asap, newborn occupies alot of time right now
and a close up;
