It was ok until recently. To the left there is now a big gap between the window and the frame and it's freezing in the bathroom now. Can't see anything that is bent from the inside. It's a horizontal opening one so a bit tricky to really look at the hinges.
on my windows I have fire egess friction hinges, they have a easy cleaning feature, this allows you to slide the window away from the hinge side of the frame, to allow you to clean the outside panel. This may have worked loose.
