Hi, I am about to tile the kitchen floor but do not have the clearance on the UPVC back door. Need about 10mm off the bottom. Can I trim this with a jigsaw? or should I try re-hanging the door higher?
Id remove the door and refit higher, if its already tight to the top i'd trim 10mm of the height, 10mm is too much to lift on the hinges, assuming it has flag hinges that is, i wouldnt trim anything off the door sash itself as the rubber bubble gasket will fall out and you'll have a draught then
