Hi guys,
i have a Grundfos Watermill Niagara 2.0 Bar Twin Impeller Positive Head Shower Pump, i installed this today as my old aqualisa 2te pump was broken,
im having some issues that i cant figure out. There is no hotwater coming out from the showerpump.
all that comes out of the main showerhead is cold water and when i turn the mixer valve to hot the water is still cold. i went to check the pump again and both inlet and outlet of the pump i can feel the pipe and its hot water but i dont understand why it is not hot at the showerhead.
the water temp if set at 50 deg and all was fine with the aqualisa before. i have even tried swapping the ends of the pump to see if it makes any difference.
so confused... can anyone help ?
