Urgent HELP!!! Jaguar 23kW combi boiler problems....
24 Jul 2008
Staffordshire
Fed up now of racking my brains over this - so defeat admitted and Ive joined this forum......
Ok - heres the problem.....
When boiler is turned on, firing sequence doesnt occur, the fan doesnt kick in etc etc / the same when the hot water is turned on......
Power ok, the 6A fuse on main PCB is ok, all terminals on ok etc etc
Is it the PCB next??? Any advise greatfully received.......The customer is sick of no heating and cold showers so need to sort out ASAP without throwing too much off their money away......
One thing I did notice was there wasnt an earth connected to the fan - someone must have pulled this off before
I will have to pull the fan out to test then - any other ideas
you are the engineer ? why are
you asking us?
either you know what your doing or you dont!
honesty is the best policy. fess up now or get no help :evil:
You should be posting these questions in the Combustion Chamber section where we will be happly to help.
The Jag fan is one of the worst to change.
TonY
Hi
Had a similar problem. If your system is full of crab it will eventually cause the pump to play-up or seize. Take the pump out and clean it up , get rid of all the black thats on the chrome shaft. This wall cause the relay on the PCB to blow. If you take the pcb out, look underneath the relays to see if it is burned. If thats the case you can wire the pump straight into the mains with a 3 pin plug as a temporary measure. If it works then you can replace the pump and pcb. The main problem would be to power flush the system. [removed]
thanks UD
