Hi chaps,
I'm in the process of refitting a radiator. I have only ever replaced an old one before but this one is new and has extendable fixings on it where it fastens to the pipes (for adjustment). When i its fixed in place the radiator leaks but not from the nuts. Water is running between the shaft and sliding component that has the nut on. As far as i can see no matter how tight the nut is done up this will always leak. How do i remedy this?
Cheers in advance
Tom
Cheers in advance
Tom
