Urinal flushes then carryies on dripping in to bowl
6 Feb 2010
Blackpool
Hey I have installed two urinals with one cistern feeding them. That when flushed the sparge pipe on one of the urinals carryies on dripping in to the urinal bowl after the flush is complete what could be causing this?
Your replies are sparge ( sic) and dispargeing (sic) Sparse and disparaging ;)
You have probably got a faulty syphon , measure it and get another or take it back to where you bought it.
sorry for the poor spelling but how could poor installation be causing this?
If your horizontal leg on one side goes slightly upwards towards the elbow it will not drain correctly. The pipe will drain back past the tee and drain out of the other spreader.
The red line is the water level. Both sides need to be parallel with it or have a fall from the tee to the elbow:
View media item 60018
Then it`ll drip from both spreaders :idea: . Might be helpful to know how long it drips for ;)
