Use two PIRs to one light? (one way PIR)
Many can be used in parallel. Common for communal stairwells but not all you need to read the data sheet.
Since 2 wire I would expect it would use the bulb as the return for the power it needs to operate and to run multi units I would select three wire versions which have a neutral to run in parallel.
