Moved into a small house 2 years ago with a Worcester 28CDi combi boiler. It works fine, but I have noticed that the pressure would very slowly go down. There are no leaks to be seen, so I assume there is a small leak at a join under the floorboards. Sort of forgot about it this summer, but now the weather has turned, it came up again.
I have just injected a sealant specifically for sealed systems and it has done wonders for the pressure, but here is my problem...
When the heating is on, pressure will now go just above 2.5 bar before it stops firing, and will remain there while heating is on. But when not in use, it drops to zero.
After using sealant, I bled air out of top rad and repressurized the system to 0.5 bar as per intructions. When it first started to rise above 2.5, I got worried and drained some water to release pressure...but it still wants to stay around 2.5.
Please, any ideas whats happening?...or what I need to do?
Thanks - Ian
Thanks - Ian
