Hi All,
Used Sentinel X800 in system for a 2 weeks and drained system and then refilled but 2 rads still refuse to get hot, then done the same process with X400 and still no joy, today I completely drained again took the 2 rads off the wall that refuse to get hot and connected the hose to them flushed out all the sludge which was quite a bit put back on the wall refilled the system and prayed, but still nothing !! Really is driving me nuts as British gas who I have a service and breakdown contract with refuse to now come out unless they power flush which is just over 1K which I just have not got.
When I feel the pipe where the pipe comes out of the wall and goes to the rad it's hot but only on the left of each rad, the right hand pipe at the rad is stone cold, so my thinking is that the microbore pipe in the walls (newish house) is block on the return flow which then means that the hot water is not flowing through the radiator. it can't be either of the rads as I know they are completely free of any blockages after hosing them for 20mins each
If I drain the system again take both rads off that are not working and then connect a hose pipe to the microbore pipe on the return side and blast mains pressure through would this clear the blockage ? OR am I just wasting my time ?
I've also installed a magnaclean which I empty each weeks since installing 6 weeks ago and each time the water is proper sludged up even though I've completely drained the system and refilled 3 times in the last 4 months. It is getting better but not to the point where I can get these 2 rads going even though I've used as stated X800 and X400.
I was going to try Fernox ds40 but I think this may be a waste of money and time as I've already used X800 +X400 as I don't think that the chemical is getting to where the blockage is in the 10mm microbore pipe. All other 15 rads are super hot with no cold spots.....
Any help/advice really appreciated as I'm getting to the point where I've tried everything and a power flush may be the only option....
