using 1 core of T+E
5 Jun 2006
Leeds
I need to provide an additional core to my central heating controller (for a separate hot water signal). I have some 1.5mm2 T+E, but obviously only need to use of of the two cores. What should I do with the second core? Should I cut it off and wrap insulation tape around the end, or use it in parallel to the first core, ie double it up?
I know that I could either replace the T+E with 3+E of install a double insulated single core, but I was hoping to use what I already had.
Thanks for advice.
I presume you are just providing a switched live through the second T&E.
If so the connect the brown as your switched live, earth as earth, then the unused blue should also be connected to earth, to prevent any voltage being induced onto that core of the cable.
I would just put a chock block on either end of the unused core.
Earthing it down is only a requirmement (or actually a recommendation?) for explosive environments - multi cores to petrol pumps etc.....although these days they use fibre for the pumps anyway (except the actual pump!)
It is a switched live only. Will see what I have the space to do in the junction box.
Great, thanks for the advice.
