Using 10m of washing machine hose to plumb fridge?
Status
Not open for further replies.
18 Sep 2004
I hope somebody can help. I've recently moved my fridge (with icemaker) to the other side of the kitchen. There is no water supply there so I bought 10m of washing machine hose and two connectors for either end (*).
Now when I switch on the supply both connectors drip. I've checked the rubber washers are placed correctly inside and retightened and checked for cross threading. Everything looks fine but still continues to leak once the water is turned on.
Would using 10m of this hose cause a problem for the connectors? Pressure?
They do look a bit cheap compared to those you usually find supplied with a w/c. Did B&Q just sell me duffers?
(*) I also actually have a brass male/male connector at the fridge end to enable the built in fridge pipe to connect. I don't think this is causing the problem though.
erm. HELP. Switching off the mains and running pipes all over the kitchen is looking like the easier option now.
Jel
you are using something for which it was not designed, do the job properly, learn by this mistake that cheap is really expensive, since you will now have to do do the same job twice.
I connected a new sink yesterday using flexi cables. And funnily enough it started leaking like yours as well! :LOL:
Anyways what you have to do is put some P.T.F.E tape on it (white tape that plumber use) Put it around each connection and then tighten.
I turned the tap on and no more leaks. Dont know if you can use it in a similar way. You should be able to though hopefully.
Got this info from a site about the tape:
"It can be wound around threads of any metal, plastic, or rubber pipes to provide leak free joints that will never freeze or harden with age."
Yup, luckily I also got hold of a plumber friend and he also said that the length of the pipe had no bearing on the leaks. Said to get some grips and give it a good tightening as he often gets leaks with those sort of connectors too. I also ordered some new connectors from an online plumbing shop and must say they are of a much better quality than the B&Q one and cheaper too. :)
Ta for posting though, with both your advice I feel a bit more confident about giving it another try and can worry about one less thing before my kitchen installer comes on Saturday.
Just got to do the opposite of you and remove the sink tomorrow so was going to get some PTFE tape anyway to bung up the pipes there with stop caps until the weekend. Will chuck some on the washing machine connectors too.
Thanks again for the contructive comments.
Jel
_____________________
lynda, moderator
please note forum rule 17, the post you replied to was made in 2004
Status
