I thought this would have been asked before but haven't found anything in the seach.
I've been plastering for around a decade and recently decided to have a go at rendering my garage.
I battened off the large wall into smaller managable sections, followed the tips on here for preparing the substrate and getting the mix right and found it went on well (thanks everyone). I can get the wall looking pretty decent with just my trowel, but obviouly still need to remove the odd high spot and fill in the low spots.
BUT when I come to level off with the feather edge it all goes a bit wrong.
Either I push lightly and almost nothing comes off the wall, or (more often) with a firmer push the render sticks like glue to my feather edge and I pull big chunks of it off the wall. I have now tried this multiple times and keep getitng the same bad result.
When am I supposed to apply the feather edge? (how soft should the render be? completely fresh and wet? slightly firm to touch? etc)
How hard am i supposed to push it against the wall?
How flat and/or smooth should I be trying to get the wall with my trowel before using the feather edge to flatten. As a seasoned plasterer I naturally try to get it as flat as possible with the trowel.
How flat am I trying to get it with the feather edge? Perfectly flat or just a bit better than a trowel finish? If the latter how much of a dip/bump can I leave in mm?
regards RBN
regards RBN
