I need to cut a hole in 2mm thick aluminium (A PC case). The aluminium is drilled with a lot of holes (it is a vent, but I need to make it less restrictive).
I have a set of wood holesaws. As I had a spare PC case lying around I tried them on that but as THAT case is steel, it barely scratched it. I wasn't really expecting it to cut it, but if it made more of an impact I would have tried it on the alu seeing as it is a softer metal.
So, what type of holesaw should I be looking to use on aluminium to make a hole around 10-12 cm in diameter?
