My central heating system is in need of a clean. It was built and then extended at least twice and has been fuzzing up the heat exchanger on the combi boiler regularly. In addition many of the radiators are getting hot at the top and sides with a cold bell curve in the centre.
I have bought and fitted a magnaclean filter and I have also bought a magnaclense cleaner unit.
To do a full clean I understand that I am supposed to drain the system, refill to about half way full on each radiator, then add the cleaner and fit the Magnaclense in place of the filter.
I am then supposed to run the system hot for an hour or so and then shut off all radiators but one, agitate that radiator with the SDS hammer head for about one minute and then open radiator two, shut down radiator one and repeat the agitation on radiator two.
I then repeat this process for each additional radiator.
Then I drain the system, refill and drain again and then add the protector. Job done.
I have a bunch of questions about the chemicals used which I will follow up with, but firstly:
Is the above procedure about right?
Thanks Guys
Thanks Guys
